 Post subject: old hp
PostPosted: Sun Feb 07, 2016 8:24 pm
Is it worth more whole?. Doesn't work though
 Post subject: Re: old hp
PostPosted: Sun Feb 07, 2016 10:11 pm
Probably not in that condition. But inside it's mostly telco class. Good find.
You may have salvageable parts inside too. Especially ic chips, controllers and CPUs. All 3 will get you a bit of a premium on eBay... eventually. The whole units when not working are generally passed on by buyers as the powersupplies almost never work right if at all, and add half nearly a third to half the weight when shipping.
PostPosted: Sun Feb 07, 2016 10:14 pm
Not counting shipping (and that /will/ be an issue) the 300 should run $20-$50 doa. The 9k unit will probably be under 20.
PostPosted: Sun Feb 07, 2016 11:04 pm
Thanks for the info. Nice and quick.
PostPosted: Mon Feb 08, 2016 12:04 am
The black box left of qa35 needs to be removed. It has a lithium battery in it. Gently rock it with a pair of plyers thr long strip with the shell. If you are interested in working it you can drill out the rivits if it's solid mounted. May have a tiny gold cap in the centre bringing it up to telco rate with the sink off.
As is everything is peripheral grade as long as you cut off the wires.
