It is currently Sat Sep 26, 2026 2:25 pm
 Post subject: Odds and Ends 1
PostPosted: Wed Apr 21, 2021 3:24 pm
Various Odds and Ends to clear my bench.
D, E F I believe came from a printer.
G, H, and I are touchpads from laptops I believe.
Thanks in Advance,
C.
 Post subject: Re: Odds and Ends 1
PostPosted: Wed Apr 21, 2021 5:43 pm
Here's my guess:
A) High Grade Peripheral
B) Low Grade Peripheral
C) High Grade Telecom
D) Low Grade Peripheral
E) High Grade Peripheral
F) High Grade Peripheral
G) Low Grade Peripheral
H) High Grade Peripheral
I) High Grade Peripheral
Laptop touchpads went as Peripheral before the split so I'll have to check with Chris.
PostPosted: Thu Apr 22, 2021 8:57 am
Based on that I will hold off on H and I, and sort the rest as noted.
C.
PostPosted: Tue Apr 27, 2021 1:59 pm
Chris says that laptop touch pads go as High Grade Peripheral. He also said that A is Low Grade Peripheral instead of High.
PostPosted: Tue Apr 27, 2021 2:42 pm
A was sent late last week as whatever it was noted before your edit. I will put H and I into the correct sorting box for next time. Thanks.
C.
PostPosted: Tue Apr 27, 2021 2:46 pm
No problem. I guessed A was High Grade Peripheral but Chris said it was Low Grade Peripheral. But Chris has said that if anyone sorts some boards into the wrong category, he will put them in the correct category.
PostPosted: Tue Apr 27, 2021 2:56 pm
Looks like you will have that chance any time now as our BEAST of a box arrived about noon. It's just a shade under 60lbs so have one of the young lads lift it to save an older back.
C.
