It is currently Sun Sep 27, 2026 5:14 am
PostPosted: Mon May 03, 2021 3:24 pm
The last of the boards in this bunch. Please help me properly classify them, along with whether I should extract any socketed IC's. Thanks for the help!
PostPosted: Mon May 03, 2021 8:43 pm
There's enough here I'm not sure about that I'll defer to someone else.
But I'll point out:
Taking ICs out of sockets can lower grade of the board, especially those Gold Cap Chips, so generally it's not recommended. Looks like some of those boards have heavy enough population you'd be safe to pull non-gold cap chips but I personally wouldn't.
PostPosted: Mon May 03, 2021 9:12 pm
Here's my guess:
Both Low Grade Peripheral but I'll check with Chris to be sure.
Gold Cap Chip Board and Low Grade Peripheral but I'll check with Chris to be sure.
High Grade Telecom
High Grade Telecom
Connector End/Low Grade
High Grade Telecom
High Grade Telecom
PostPosted: Mon May 03, 2021 9:20 pm
Yes, taking IC's out of their socket more often then not hurts the grade of the board they were removed from.
marked141 wrote:
But I personally wouldn't.
I agree here too. It takes a lot of IC's to reach a pound which probably isn't worth the money you'd lose by removing them and thus lowering the value of the board (in most cases).
PostPosted: Wed May 05, 2021 4:50 pm
ccussins wrote:
Here's my guess:
Chis says I'm correct here.
