It is currently Wed Oct 28, 2026 9:44 pm
PostPosted: Fri May 21, 2021 5:09 am
Copper/Aluminum Radiator Heatsinks, do they grade as aluminum/copper heatsinks, they are a little different from the type in the payout rate pictures, thank you for your help.
PostPosted: Fri May 21, 2021 11:54 am
they are the same, as long as they have both copper and aluminum they all go together no matter what shape and size they are.
PostPosted: Fri May 21, 2021 12:01 pm
You also want to make sure they are clean of any steel, plastic, screws, fans, etc.... If they do have contamination, they will be bought as dirty radiators.
