It is currently Fri Oct 30, 2026 12:49 pm
 Post subject: Help with board grade
PostPosted: Thu Jun 03, 2021 12:10 am
Help with boards id
Here to learn and make some $$
PostPosted: Thu Jun 03, 2021 1:58 pm
Sorry sent this late last night did not mean to resubmit
PostPosted: Thu Jun 03, 2021 3:34 pm
I'm thinking high peripheral at least, possibly better. Should probably remove the white brackets/faceplate.
PostPosted: Mon Jun 07, 2021 3:23 pm
@Markd141, I used to send same board as telco just not sure now if it's low telco or high, with or with out bracket
PostPosted: Mon Jun 07, 2021 3:51 pm
I'm checking with Chris since these boards can probably go Low Grade Telecom.
PostPosted: Mon Jun 07, 2021 8:45 pm
I did say at least high peripheral. The brackets are what made me go lower, but ccussins will get you a definite category as soon as he can.
PostPosted: Mon Jun 07, 2021 10:06 pm
Markd141, Ccussins, really appreciate you guys taking time to grade, I'm was gone for a while I'm just learning
PostPosted: Sat Jun 12, 2021 9:51 am
Chris says it's Low Grade Telecom.
PostPosted: Sat Jun 12, 2021 11:51 pm
OK, thank you! Will continue our journey when you return
