It is currently Sat Nov 07, 2026 12:12 pm
 Post subject: Help with board grade
PostPosted: Thu Jun 03, 2021 1:47 pm
Please grade boards
Here to learn and make some $$
PostPosted: Mon Sep 14, 2026 5:47 pm
Without a doubt. As is. They will go Low Telecom.
But. Remove that plastic bracket. And any relays. Which I figure those small packages are surrounded by the white axial capacitors. Also. Snip off those power resistors. I think I see a small coil on each. Remove those. And maybe remove all the white axial capacitors. You may get High Telecom.
It is a tough call. To get High Telecom. But. Both boards are Low Telecom in my opinion.
