It is currently Fri Oct 30, 2026 4:35 pm
PostPosted: Mon Jun 14, 2021 10:26 pm
hi, tape drive boards better pics , this type of drive comes with 3 boards bolted together i will clean up before shipment wires extra metal .
PostPosted: Mon Jun 14, 2021 10:46 pm
It was multiple boards! Thanks for clarifying for us. As a whole unit you may be looking at low or high peripheral. I'd lean toward high if the standoffs are brass.
Top board: High Telco, just make sure that excess steel bracket/standoff comes off.
Middle: Low Telco. I see some gold pins on the right that seem to be missing their friends. Shouldn't be an issue but this one might be able to go high telco too so don't take off any value if you can help it.
Bottom: High Peripheral. Not sure what's there with the plastic, if that's all it is then your at least at high peripheral, might be able to go higher with the plastic off. If there's a chunk of steel or something annoying in there then it could go lower.
As always this is my best guess and if lostinlodos or someone with more experience says otherwise I defer to them.
