It is currently Fri Sep 25, 2026 7:36 am
 Post subject: Grade help 5
PostPosted: Fri Jun 18, 2021 2:24 pm
I have no idea about the grades on these 2. Just keep in mind that on board 1 I can remove the black buttons from the back. And board 2 the "silver" connectors each have a really good gold plated pin inside them. These pics are of the same 2 boards front and back.
 Post subject: Re: Grade help 5
PostPosted: Fri Jun 18, 2021 9:08 pm
Long rectangle is at least low peripheral, don't imagine the buttons weigh much but taking them off might make it easier to throw in high peripheral.
Squarish like the similar boards you posted I'm thinking midgrade but it might make it in low peripheral.
I think I need to change my signature so I can forego writing:
"I'm taking my best guess, if someone with more experience says different I defer to them." :D
PostPosted: Sun Jun 20, 2021 1:52 am
Thank you Marked141 for all of your input. I know it takes some effort to sort through these posts, and then come up with good answers for them so I try to give clear pics and as much info as I can on the boards I need help with. All of your guys efforts are appreciated very much. MAL.
PostPosted: Mon Jun 28, 2021 2:55 pm
The top board is High Grade Peripheral with the buttons removed. The other board is Low Grade Peripheral.
