It is currently Sat Sep 26, 2026 11:21 pm
PostPosted: Wed Jul 07, 2021 2:37 pm
I've been searching the internet but haven't found an answer. Are the pins in an ATX connector brass? If not, what type of metal are they?
PostPosted: Wed Jul 07, 2021 8:30 pm
Most likely nickel plated brass.
If you're just scrapping it you could pull one of the pins and check. If it sticks to a magnet it may be steel or, because nickel is magnetic, nickel plated. Then you can take a file to it or bend it until it breaks from the stress. If there's yellow under the silver color then plated brass. If it's more pink under the silver then it's plated copper.
PostPosted: Thu Jul 08, 2021 9:00 am
Can they be added to the connector category on boardsort?
PostPosted: Thu Jul 08, 2021 11:00 am
No, they must have gold plated pins. Somewhere I have a post about connector ends, I will try to find it later.
PostPosted: Thu Jul 08, 2021 3:20 pm
I just leave ends like that on and take to my local scrap yard. Unless your local yard has a separate category for connector ends/plugs just leave it on.
PostPosted: Thu Jul 08, 2021 11:01 pm
Here is my topic on connector ends.
viewtopic.php?f=3&t=18855
Depending on the yard, you may have to remove the connector ends. Mine requires the ends to be removed from the wire, otherwise it is downgraded to a lower category.
Once the connectors are removed, the gold pin ones go to boardsort, and all other non gold connectors go in to the sheet iron pile. But I keep most of the computer power supply connectors for later experimentation for removing the brass out of them.
