It is currently Mon Sep 28, 2026 6:07 am
PostPosted: Mon Jul 12, 2021 3:34 pm
Looking to get clarification on how to classify these prior to shipment.
G is the Aluminum heatsinks where the chip is bonded to the sink and ripped off the board above it, F.
Thank you in advance!
C.
PostPosted: Sun Jul 18, 2021 10:29 am
A) Midgrade
B) High Grade Peripheral
C) Low Grade Peripheral
D) Midgrade
E) Low Grade Peripheral
F) High Grade Peripheral
G) To get those chips off, you should try heat. If the heat doesn't work, you could try running a razor blade around the edges while prying up with a screw driver. After you get those off and if you remove the plastic pins and springs they can go as Clean Aluminum Heatsinks.
PostPosted: Mon Jul 19, 2021 9:14 am
Sorted, Thank You.
C.
