It is currently Thu Aug 06, 2026 5:35 am
 Post subject: ID Help & What To Remove
PostPosted: Wed Jul 14, 2021 10:25 pm
Hello,
Brand New to E-Waste and Boardsort, so I will probably have a ton of questions in the coming weeks. Any idea what this would be categorized as? Here is a front and rear picture of the board, and the unit it originally came from. Does anything specific need to be removed or would it be sent as is? I have a few of these curently. Thanks
PostPosted: Thu Jul 15, 2021 9:44 am
You should remove the heatsink, the shields, and the wire. Then post a another picture of it.
PostPosted: Sat Jul 17, 2021 9:30 am
Here are the updated photos (with a front and back view) for identification. All heatsinks have been removed even though they may not be reflected in the current photo.
Thanks Again
PostPosted: Sat Jul 17, 2021 2:21 pm
All should be high peripheral.
On these particular boards with gold fingers I would carefully cut the fingers for clean GF rate.
PostPosted: Sat Jul 17, 2021 7:12 pm
On second thought those boards with the gold fingers.....those may go low telco.
I would suggest emailing Chris for positive ID.
PostPosted: Sat Jul 17, 2021 11:37 pm
I think you were right the first time rdw. I can't see the amount of fingers justifying a jump from high peripheral.
I could be wrong but Boardsort is pretty good about upgrading boards if they can be. So, better to have it upgraded than downgraded after you have your quote and were expecting a certain amount.
To make sure the board has the best chance of going better you'll want to get that last shield off the back and any of those connector ends (labeled J502-J504 on the board) should probably come off too.
PostPosted: Sun Jul 18, 2021 9:57 am
I appreciate info. Thanks again
