It is currently Sun Sep 27, 2026 5:28 pm
 Post subject: Hard Drive Questions
PostPosted: Sat Jul 17, 2021 7:23 am
So I had a couple questions about Hard drives, specifically hard drive boards.
First question, do I need to separate sata boards from pata boards from sas etc etc? Or is it ok if it comes from a hard drive, it's ok.
Second. SSDs? What do they count as? Are they also "hard drives"
Finally, I see there is a differentiation between Hard drive with Board & Hard drive Punched with board. What about just boards if they have been punched.
Thanks.
 Post subject: Re: Hard Drive Questions
PostPosted: Sat Jul 17, 2021 11:55 pm
Boardsort does not differentiate between data connectors, that I know of, at this time. If you have a local buyer, other than Boardsort, they may. My local buyer made a point to ask me what I had before we settled on a price that would give him some leeway if there were more SATA than IDE boards or full length (covered the entire side of the hard drive) vs half length.
SSDs should still be HDDs but this could have changed or may be dependant on format of the SSD. I'm thinking 3.5"SSD vs a USB.
The hard drives with boards vs hard drives punched/bent with board are for whole units. If a board by itself is damaged then the condition of the board will determine if it is still a HDD board or not. If it's missing the gold pins or ICs it'll lose value. If the board is broken in half if can still go as a HDD board if you keep the two halves together. If half is missing it will more than likely lose value. How much value? Like I said, depends on the individual board.
Post pictures if you're not sure.
