It is currently Wed Oct 28, 2026 11:04 pm
PostPosted: Tue Nov 30, 2021 12:49 pm
Have several of these phone slot cards from an old Stromberg Carlson system. Gold fingers, each side, tracings to which the phone line wires are connected on each side. With the wire removed, what would they go as? I posted the photo of the aluminum cutout frame with the slot connectors, regular connecter end type with wirewrap pins about 1 1/2 inch long. No board involved other than these slot connector cards. Is there enough gold to qualify as gold fingers if clipped?
PostPosted: Tue Nov 30, 2021 3:07 pm
Based on similar cards I posted you might be able to get high peripheral but I feel like this may be one that Chris would need to make the call on if you want to be sure.
Unless Lostinlodos still visits this side of the forum and would like to share his thoughts? ;) ;)
PostPosted: Tue Nov 30, 2021 3:49 pm
Thanks.
