It is currently Thu Oct 01, 2026 8:38 pm
 Post subject: 08/08/21 grade 1
PostPosted: Sun Aug 08, 2021 4:41 pm
These pics are all of the same board. It's a very large board so I added several close ups of different sections of it. I also added a close up of the Dallas chip on this board. It doesn't seem to be a real time Dallas chip, and I am not sure if it contains Mercury or not. Do I need to remove it from the board? Please grade. Thank you. Mal
 Post subject: Re: 08/08/21 grade 1
PostPosted: Sun Aug 08, 2021 5:09 pm
That is a Dallas box and it does need to come off the board. It has a coin cell battery built in. If it's socketed that's an easy removal, if soldered I usually have no issue sliding a flathead screwdriver under one of the short sides and popping it right off.
PostPosted: Sun Aug 08, 2021 5:15 pm
Thank you Marked, I am removing it now.
PostPosted: Sun Aug 08, 2021 5:23 pm
No problem.
I'd lean toward high telco on the board. Haven't been doing so great with some of my grade opinions lately though so I'm going to hold off on the other ones you've posted. Going to try and take some time to re-peruse the forum to get a better handle on things.
PostPosted: Sun Aug 08, 2021 5:29 pm
I was thinking H. Tele myself on this one too. But ya, lately I have been going through such a wide array of boards that I have no confidence in self grading. Anyways, thank you for your input.
PostPosted: Fri Aug 13, 2021 11:09 am
I'm checking with Chris.
PostPosted: Wed Sep 01, 2021 2:29 pm
bump
PostPosted: Thu Sep 09, 2021 3:02 pm
Chris says it's High Grade Telecom.
