It is currently Wed Sep 30, 2026 3:28 pm
 Post subject: PH 10-11
PostPosted: Mon Aug 23, 2021 12:41 pm
PH 11 shown with and without EMI shields
 Post subject: Re: PH 10-11
PostPosted: Tue Aug 24, 2021 7:52 pm
The boards that have the purple battery on them I would suggest sending to your hazmat drop off because the battery appears to be soldered and glued on the board. Wait for someone else to reply about the battery because there may be an easy way to get it off.
PostPosted: Wed Sep 01, 2021 10:05 am
I don't have any clue about the batteries but as is, all these boards should be High Grade Peripheral. In PH-10, remove all those shields on the board that is a lighter green color and repost. If there are chips under all the shields there is a good chance that the board will get a higher grade.
PostPosted: Wed Sep 01, 2021 11:20 am
The purple button battery, PH11, will pop off with a good flat blade screwdriver.
No need to take to hazmat. Any Batterie+, Best Buy or similar drop off will take all of your old, dead batteries.
RFIII
