It is currently Wed Sep 30, 2026 11:22 am
 Post subject: Grade PH 28-32
PostPosted: Mon Aug 23, 2021 12:52 pm
 Post subject: Re: Grade PH 28-32
PostPosted: Wed Aug 25, 2021 7:18 pm
32 - top two or left two would be GFC, better rate if you remove plate.
The others are prob low perif, but still remove plate
31 - Take them out of plastic, typically Telco
30 - would think perif high, back is basically blank
29 - I would pull the plated mini connectors on the back, the board I think is perif low either way
28 - Too much heavy junk (transformers, large caps wiring), as is thinking low if they would buy it at all. W/O big Junk prob lo-perif or mid.
PostPosted: Wed Sep 01, 2021 9:59 am
I agree.
32) Remove the metal plates on the two boards with the longer fingers for Clean Gold Finger Cards. Remove the metal plates on the other two for High Grade Peripheral.
31) Like sail4life said, you need to remove the covers and repost.
30) High Grade Peripheral
29) Low Grade Peripheral
28) Low Grade
