It is currently Sat Sep 26, 2026 6:56 pm
 Post subject: 10 more boards | G
PostPosted: Mon Sep 27, 2021 2:24 pm
Thank You!
 Post subject: Re: 10 more boards | G
PostPosted: Mon Sep 27, 2021 6:41 pm
64,65,68 are basically identical.....??? would be easier for people to help you if you didnt duplicate. thanks. edit also 62, 63 same but rotated 180. some of your other posts also have duplicates.
PostPosted: Wed Sep 29, 2021 8:24 am
Take the grades with a grain of salt, but the bits about cleaning stand regardless the grade
70 - Lo Perif
69 - Lo Perif
68 - see 65
67 - Telco Lo unless grader feeling generous
66 - Remove wire, Mid
65 - This is what 64 should look like - Prob Hi Perif, assuming more junk on back
64 - Pull transformers, standoffs, and connectors
63 - Same as 62
62 - Hi Perif? Pull connector and if gold pin put it with gold connectors
61 - Lo Telco?
