First I live close to Boardsort so I will be dropping off personally. Also The boards I am posting for ID are all from Brunswick AS 80/90 electronic bowling scoring systems and I have multiples (20-100 of each) I have been reading thru the forms for about a year. Although I feel I am getting a better idea of how to identify boards I am still a bit confused.
Board 1 I presume is a gold finger card, do I need to remove the red button reset switches, and I presume the black square box in the lower left corner is a battery that needs to come off.
Board 2 low-midgrade?
Board 3 not sure of the grade, should I remove the socketed IC chips?
Board 4 GF Card? Once again do I remove the socketed IC Chips?
Board 5 GF Card? remove socketed IC chips?
Board 6 Not sure of grade, once again remove IC Chips that are socketed?
Thanks for your help
