It is currently Wed Aug 05, 2026 12:58 am
 Post subject: A few boards for grading
PostPosted: Thu Oct 14, 2021 9:32 pm
Grades please.
Thanks
PostPosted: Fri Oct 29, 2021 5:18 pm
No one?
I am thinking high grade telco or maybe low telco for the top 2.
Maybe peripheral for the bottom 2..
PostPosted: Fri Oct 29, 2021 9:09 pm
I've looked at your boards a couple times and couldn't recognize some of the components to be sure if they added or took away value from everything else on the boards, so I didn't offer a grade thinking someone else would get to it. Obviously that didn't happen. D:
Anyways, you should always remove any plastic/steel that can be removed without damaging the board, so get those end brackets off.
Two rectangular in the first pic I think you're good at low telco.
Squarish one is the one I have the most uncertainty on, you're definitely good for low peripheral but it could go much higher, I just don't know enough, of about 3/4 of the board, to be confident to give it a better grade (maybe it's the glare...).
Rectangular one I think can go into high peripheral.
PostPosted: Fri Oct 29, 2021 9:28 pm
Thank you marked..
PostPosted: Fri Oct 29, 2021 9:34 pm
No problem, sorry you had to wait so long. Thanks for bumping your question back up so I could see it again.
