It is currently Mon Sep 28, 2026 11:32 pm
PostPosted: Mon Oct 25, 2021 1:03 pm
Need help identifying
PostPosted: Mon Oct 25, 2021 3:22 pm
I'm not sure on the grade but to get the best grade you'll want to pull the fuses and if the wire clamps are able to be pulled out, do so and that should put you at at least high peripheral. I'm sure someone else can help verify the grade.
