It is currently Tue Sep 29, 2026 9:04 pm
PostPosted: Wed Oct 27, 2021 10:04 am
I need help with identifying these boards.
PostPosted: Wed Oct 27, 2021 8:34 pm
18A connector end
18B gold fingered ram
18C gold fingered ram
18D not sure, my best guess would be connector end but it might be better to trim the gold fingers and throw away the rest
18E no grade
18F gold fingered ram if there are ram chips on the other side, blank ram if there isn't (which is unlikely).
18G not sure
18H gold fingered ram
18I hard drive board
18J connector end
18K depends on the cap on the other side
18L I can't tell if those are pins or not. If there are pins, then green fiber with metal if there is a cap, green fiber no metal if there is no cap. If there are no pins, then no pin CPU.
18M backplane
18N low grade
PostPosted: Wed Oct 27, 2021 9:02 pm
As noted in another one of you're posts, please be considerate of the people offering their opinion on grade by reducing the number of boards per picture and post. PickleJar and I are doing our best but we clearly can't see what we need to to help you. Also, if we can only see one side of the board we only have half the picture, please post both sides if there is anything on the other side.
Also, if you will click on the "Payout Rates" and hover/click/tap on the different grades you should get an idea of what a lot of these boards are. That can help you reduce the number of boards you need to post. That's not to say we don't want to help but help us, help you.
18E) SD Cards may have value (based on previous threads) but you'll need quantity and to talk to Chris directly to see what rate he can give you.
18G) Looks like some pins but yeah, picture not clear enough.
18K) Same, need to see other side
18L) Agreed
cron
