It is currently Wed Sep 30, 2026 10:00 am
PostPosted: Sun Oct 31, 2021 6:29 pm
Delco Tahoe Amp Board ID:
Heat Sink Board ID:
NUVIDIA Board ID:
N1996 Board ID:
PostPosted: Sun Oct 31, 2021 6:58 pm
Just my 2 cents :)
Delco Tahoe Amp Board ID: Low Grade
Heat Sink Board ID: Gold Finger Card Remove Heatsink upgrade to clean GF
NUVIDIA Board ID: High Peripheal ?
N1996 Board ID: High Peripheal ?
PostPosted: Mon Nov 01, 2021 10:46 am
If they have gold fingers why wouldn't they be gold finger cards?
PostPosted: Mon Nov 01, 2021 12:57 pm
Could be I was just taking a guess. I have a
had a couple like this go for High Peripheal. But may go as Finger Card.
PostPosted: Mon Nov 01, 2021 1:26 pm
I'm still learning how to classify boards so I was just wondering. It looks like both of those boards are video cards with gold fingers so I would guess GCFs.
PostPosted: Mon Nov 01, 2021 3:11 pm
Low grade on the first make sure you trim the wire off. Also check the metal heatsink/bracket to see if it's steel or aluminum/brass/copper and then, if it's worth your time to remove vs whatever material it's made of, do so.
The three are all gold finger cards.
The first one needs the heatsink removed for the best grade. If it's not coming off or feels/sounds like the chip underneath is coming with it, stop. Try heating the aluminum and try again to remove it.
The second looks good.
The third is probably okay but looks like someone tried to pull the DVI/HDMI ports off or they were damaged trying to pull something else. Try not to pull any ports off, it could lower the value of the board.
