It is currently Fri Oct 30, 2026 11:38 am
 Post subject: Any value?
PostPosted: Wed Nov 03, 2021 5:01 pm
Just wondering what these chips are?
And if they have a category on there own?
Board is broken so I would just remove these
 Post subject: Re: Any value?
PostPosted: Wed Nov 03, 2021 6:14 pm
Those are transistors, not ICs. The board is midgrade
PostPosted: Wed Nov 03, 2021 6:15 pm
Will Boardsort still accept this even though it's only part of a board?
PostPosted: Wed Nov 03, 2021 9:01 pm
Don't intentionally send in pieces like that all the time but yes there is still some value so it can go.
Transistors typically have a plated copper backing to help dissipate heat (and are often attached to a block of aluminum). Depending on your local yard if you have loose transistors they may take them as copper breakage or copper content.
PostPosted: Wed Nov 03, 2021 10:40 pm
local yards around here are useless. They buy ewaste in a whole for 10cents a lb.
Peripheals at 3cents a lb.
Now this is Canadian money to, so might as well be Monopoly Money compared to U.S. curency lol.
SO it's pretty much useless as a small operator too make any money :(
PostPosted: Wed Nov 03, 2021 11:58 pm
I have the same issue in Texas, though it's getting better as more companies realize there's value.
But just the transistor without any board is largely copper, if you can convince a local yard it is what it is then that is just another option if you end up with a large number of loose transistors.
PostPosted: Thu Nov 04, 2021 12:28 am
Thanks Marked141. Wil be heading to my local yard n Friday so I think I will bring in a few and see what they have to say or offer :)
Cheers
PostPosted: Thu Nov 04, 2021 2:16 pm
Dug up a couple of Lostinlodos' old posts about these.
Here:
viewtopic.php?f=3&t=21301&p=42165&hilit=Transistor#p42165
And here:
viewtopic.php?f=3&t=1212&p=4078&hilit=Transistor#p4078
Looks like I generally remembered correctly but Lost is far more experienced so if there's any discrepancies I defer to Lost.
PostPosted: Thu Nov 04, 2021 9:22 pm
Thanks for the info Marked141.
Interesting to say the least :)
