It is currently Fri Oct 30, 2026 1:58 am
PostPosted: Fri Nov 05, 2021 2:32 pm
Thank you
PostPosted: Fri Nov 05, 2021 9:59 pm
A) High peripheral at least, might could get low telco
B) Low peripheral
C) CD/DVD Board
D) Metal cover next to the SIM card slot? pull it off if you can, then high peripheral.
E,F) Low Telco at least, possibly high
G) High Telco
H) Low Telco at least, possibly high
I) Leaning high peripheral
J) From the boards appearance I'm assuming there was a glass display on one side, if that's incorrect forgive the following lengthy writeup. I'm not sure if the screen on this was something I or someone else suggested removing, but I started looking to see if you needed to be more thorough in removing the pins and such that are left and what I'm seeing looking through posts by Lost is that these screens can have value on their own in the range of high peripheral but need to be reviewed (not by me, cause I didn't know).
Anywho, if there's no glass left I think you're at high telco.
K) High peripheral
