It is currently Wed Oct 28, 2026 7:40 pm
PostPosted: Thu Dec 02, 2021 12:22 pm
Checking to see what category these would fall under and if boardsort purchases these. These are about 2' x 2' and fairly heavy. These are two different boards front & Back.
PostPosted: Thu Dec 02, 2021 6:47 pm
Sorry, I can’t see the boards well as the photos aren’t very clear. Are those all connectors with gold pins? If so, both are backplane.
PostPosted: Thu Dec 02, 2021 10:36 pm
If you read this before the edit... I mixed this post with a different one that also had picture issues... anyways, edited down:
Note on pictures, the resolution isn't great so if you can find a better camera that would be great, if not try and make sure you have a consistent light source across the boards. Try to fit the boards so they fill the entire frame, turn the camera vertical/horizontal if necessary
PostPosted: Fri Dec 03, 2021 12:23 pm
Lot's of recent posts with picture issues. I have a hard enough time figuring out the grade with quality pictures! :)
