It is currently Wed Oct 28, 2026 8:49 pm
PostPosted: Thu Dec 02, 2021 11:21 pm
PostPosted: Thu Dec 02, 2021 11:49 pm
These appear to be high telco. Click the links for example of slot processors and trimmed slot processors
This post isn't as bad as the GFCs but you're going to want to take better photos if you want anyone to be confident they're giving you a good assessment of the boards you post.
You'll want:
1) a good camera that focuses and has good resolution, and
2) a good consistent light source that doesn't put a glare on the boards or leave any in shadow, and
3) to frame the boards. That is, make sure you get as close to the board as possible without cutting off part of the board (this will help if your camera isn't great). Take multiple pictures of fewer boards instead of one picture of many if necessary.
Also, you may need to take pics of both sides of a board to get an accurate grade. If there's nothing on the back then you can just make a note of that in the post instead of uploading backs of every board or set of boards.
