It is currently Wed Oct 28, 2026 7:52 am
PostPosted: Thu Dec 09, 2021 10:34 am
Attached are pic's of 2 boards from Telco equipment rack.
1 has several, what look like gold tab IC's.
Not sure about the other.
Thanks
PostPosted: Thu Dec 09, 2021 3:19 pm
There's a lot of transformers(or similar) on both boards that are going to keep the grade from telco in my opinion. You should pull off the front bracket and the steel that runs the length and has 3 screws. I'm not sure what the large square component is on the one board, if the metal can pull off cleanly I would remove that too.
Right now I'm sitting at high peripheral on both but the second might have a chance to go higher depending on that large square component. Might take another picture of that from a different angle if it can't come off.
PostPosted: Fri Dec 10, 2021 4:56 pm
The example picture for the low telecom boards has a lot of transformers on it. I agree that all metal brackets and such should be removed, but why wouldn't this fall into low grade telecom?
There was a discussion recently of the low grade telecom board.
viewtopic.php?f=3&t=21542&p=43034#p43034
PostPosted: Fri Dec 10, 2021 10:57 pm
I have said before low telco is not my strong suit. I have also said if I'm not sure I tend to grade lower so that if there's a surprise in the board being a different grade when it arrives in Boardsort's hands, that it's a good surprise and not a bad one.
That being said if there's no consensus here in the forum or you just want to go straight to the source, send an email to Chris (boardsort) with a link to this topic.
