It is currently Sat Nov 07, 2026 4:19 am
 Post subject: Some Boards 3-9-2022
PostPosted: Wed Mar 09, 2022 5:21 pm
Greetings,
Here are a total of 8 boards. Some of these I am going to guess and see if I'm in the ballpark with grading. Others I'm not so sure about. Boards #3 & 8 have rear photos. I appreciate the help.
1) High Peripheral
2) Mid Grade?
3) Mid Grade?
4) Mid Grade?
5) High Peripheral
6) Mid Grade or Low Peripheral
7) Low Peripheral
8) Typically High Peripheral, but wasn't sure if it could slide into low telco
 Post subject: Re: Some Boards 3-9-2022
PostPosted: Mon Mar 21, 2022 10:57 am
Bump
PostPosted: Tue Mar 22, 2022 1:02 pm
Here's my take on them.
1. High grade periph
2. High grade periph (those round black spots are IC chips)
3. Low grade periph
4. Low grade periph
5. High grade periph
6. If you removed the two gray tubes, the copper coil, and the two transformers on it, I would think High grade periph. As it sits, ya mid-grade or low grade periph.
7. You could toss this into the high grade periph pile.
8. This one is close. I personally would think because of the couple of IC's on the backside, it might be just enough to push it into low grade tele.
I would try to get a second on this lot. Most I'm very sure of, but a couple I'm not.
Good luck my friend.
PostPosted: Wed Mar 23, 2022 10:05 am
Thanks for your help I appreciate it.
