It is currently Sat Sep 26, 2026 9:14 pm
 Post subject: Board ID #2 5-18-2022
PostPosted: Wed May 18, 2022 10:59 pm
Here are 5 boards.
1) High Peripheral
2) Small Socket Colored Motherboard? Came out of an "all-in-one" if I remember correctly
3) Laptop Motherboard
4) No idea
5) No idea
Thanks
PostPosted: Thu May 19, 2022 10:33 pm
Not sure what happened with your photos this set; seems to be a lot of blur in these.
1) Sounds right
2) Can we see the other side? Make sure you remove the battery. You're probably correct
3) Can we see the other side? Mentioned on a similar board (posted by another) the steel brace that holds the heatsink for the CPU, I don't know if it needs to be removed but my personal preference is to always pull that
4) Think this can manage high peripheral. From a security camera or similar thing
5) Leaning low peripheral
