It is currently Sat Sep 26, 2026 1:42 pm
 Post subject: TV boards
PostPosted: Fri May 20, 2022 2:24 am
Number one is from a rear projection TV the rest are from flat screen TVs, I have so many flat screen TV boards.
Some of them like number three I wonder if I get a different grade taking the larger connectors off.
Some of them like number two it looks like I could get low Telecom for half the board if I were to break it in half.
Number four has a brass threaded cable connection attached to that metal box I'm not sure if I should take those off I have been.
 Post subject: Re: TV boards
PostPosted: Fri May 20, 2022 6:24 pm
2-4) Generally go high peripheral. The coax/cable box doesn't necessarily need to be removed just pull the shield(s) off the top/sides of the box. The connectors don't need to be removed either. My understanding is that breaking boards is frowned on. Probably not as much as depopulating the components from the board but still, not recommended.
1) Not certain, I'd put it in low peripheral.
