It is currently Fri Sep 25, 2026 1:54 pm
 Post subject: First Try--Questions
PostPosted: Mon Jul 04, 2022 12:58 pm
Hi, a couple questions>
1) is it better to send one box when it is full and ready, or save up boxes and send when I have several?
2)What about packing a "six-pack". that is, 6 small flat rate boxes inside a medium flat rate. Fits perfect.
3) is there a quote for ram that is blank on one side and populated on the other?
Thanks for helping me get started.....hal
 Post subject: Re: First Try--Questions
PostPosted: Mon Jul 04, 2022 2:14 pm
1-2) It's going to be entirely up to you. As long as your material is sorted and stays sorted once it gets to Boardsort, get the material in the box(es) however you can. You'll also want to make sure the shipping cost doesn't cost more than the material you're sending.
I personally fill individual boxes/storage containers up until the box is full or I can combine anything to fill a box.
For instance this is a shipment I sent awhile back.
I had enough pinless processors to fill the bottom of a large flat rate box. Over that I put a cardboard separator.
Not pictured in the box but I placed other sorted processors on top of that so they fit pretty tight.
Again not a great picture; but on top of everything else I had enough room to send in some batteries; always fun to tetris things in.
Or another box that was just one item, HDD boards:
I pack all of this very tight so there's no movement of material inside the box; then I tape the box extremely well; every edge of the box is taped and several wraps all the way around in different locations so that every face is taped at least once. Overboard? Maybe. But no material lost yet.
3) RAM that is manufactured with chips only on one side are still paid for as Gold/Silver/Tin RAM. Blanks are specifically manufactured with no chips. If you have RAM that is missing chips you may or may not get the higher rate depending on how many chips are left.
PostPosted: Mon Jul 04, 2022 5:40 pm
Thanks for your help! hal
