It is currently Wed Aug 05, 2026 4:20 pm
PostPosted: Thu Jul 28, 2022 2:30 pm
Hi everyone. Need help in grading these peripheral boards. Also back in the day mouse boards with gold legged ic's went as peripheral instead of mid grade. Is that still the case? Thanks in advance.
PostPosted: Fri Jul 29, 2022 12:19 am
Been having some picture issues from different people lately. These are good enough to tell what's there for regular scrappers but newer people aren't going to be able to tell much. If you need to, take more pictures with fewer boards in each. Make sure you orient the camera in a way that the boards take up more of the frame. Your lighting is great though!
Except for 1 and 3 high peripheral on all of these.
1 might be high peripheral but I'd personally stick it in low peripheral from not being sure.
3 might have enough there to get into low telco.
PostPosted: Fri Jul 29, 2022 1:38 pm
Thanks marked141 for the help. I'll take your advice and post no more than 4 boards a Pic. Hope that helps with people's resolution issues.
