It is currently Thu Oct 01, 2026 8:58 pm
PostPosted: Mon Oct 10, 2022 1:33 am
Here the the link:
https://youtu.be/zTO5vk66MwE
Please let me know if it isn't working.
Thank you all!
PostPosted: Mon Oct 10, 2022 10:54 pm
I didn't think to point this out on your earlier post but here's a video on motherboards from Boardsort.
1) Looks to be an AMD motherboard which would fall under Small Solid Plastic Socket Motherboard (AMD). Color of the board makes no difference on this grade
2) Yes Large Socket Motherboard. Color again isn't an issue on large sockets. Sounded like you say the gold tab chips were going to come off? Maybe I misheard; but don't pull the chips if you were thinking about it.
3) Looks like high peripheral to me. There are numerous IC chips and the ports probably have some gold plated pins. Yes, there are lower value components but it's not like there's a half pound transformer on the board.
4) I'm a bit on the fence, I want to say high peripheral but I might stick it in low peripheral from being uncertain. It's probably from a display of some sort; looks similar to the laptop equivalent of a fluorescent light fixture's ballast (there's probably a term for that besides ballast but...) It changes the voltage so that it's high enough for whatever light source was being used.
5-9) Clean gold fingered cards. No, don't take anything off.
PostPosted: Wed Oct 12, 2022 5:03 am
Thank you for your reply! I did happen to find that video after I posted mine.
I'm finding most of this easier now. Except for a few boards here and there.
I dont plan on pulling anything. Unless I see something on a low grade board.
Thanks again!
