It is currently Mon Nov 02, 2026 9:10 pm
PostPosted: Thu Nov 10, 2022 12:42 pm
Anyone able to help me sort these? Thank you
PostPosted: Fri Nov 11, 2022 11:59 pm
Looks like high peripheral and up but can you remove any batteries you see (I see at least two on one board and one on another), remove the large aluminum heatsink on the one board with another board attached on top of it and separate those boards so the components are visible and take another picture of those and the two on the other side that are cut off. And pull that one extraneous cable.
I have never seen a memory module like the four yellow ones on the one board, without knowing what to expect, I can only advise to cautiously see if you can disassemble one so you can get a picture of whatever is in there.
