It is currently Sun Nov 01, 2026 7:14 am
 Post subject: Two boards here
PostPosted: Mon Nov 21, 2022 4:35 pm
Found the larger board on its own, not sure what it came out of. Not sure what grade? Decent (IC Chip?) Population.
The smaller board is pulled from a monitor. Wanted to know if these typically grade as high peripheral or mid grade so I know if theyre worth pulling in the future. Thanks.
 Post subject: Re: Two boards here
PostPosted: Mon Nov 21, 2022 11:28 pm
1. High peripheral, remove heatsink and bracket.
2. At least low telecom, possibly high.
PostPosted: Tue Nov 22, 2022 2:14 pm
Thanks for the insight, how do you tell if its a telecom board like that?
Also glad to know that the monitor board is high peripheral, good to know that monitors are worth splitting open for the single high grade board
PostPosted: Tue Nov 22, 2022 10:21 pm
Mainly the chip population, and on this example the overall lack of other large, bulky, and/or heavy components like large capacitors or transformers.
