It is currently Sat Nov 07, 2026 12:51 pm
PostPosted: Sun Dec 18, 2022 4:21 pm
Please help Identify & Grade Thank You !! D.E.F. !
PostPosted: Fri Jun 05, 2026 10:10 am
All High Peripheral.
PostPosted: Fri Jun 05, 2026 11:30 am
It is an apple mobo. Says apple 2002 in the top right.
PostPosted: Fri Jun 05, 2026 11:50 am
Lost has graded 5.25" floppies from clean gfc to Telco in the past.
viewtopic.php?f=4&t=3135&p=10165&hilit=Floppy#p10165
viewtopic.php?f=4&t=1322&p=4471&hilit=Floppy#p4471
PostPosted: Fri Jun 05, 2026 12:16 pm
3.5" are fairly standard. All gold pins still present, high peripheral. Otherwise midgrade
5.25" will likely vary more but intact should grade fairly well compared to smaller drives.
PostPosted: Fri Jun 05, 2026 5:18 pm
This is the only mention I can find of things outside CD/DVD, going as such viewtopic.php?f=11&t=22775 :
lostinlodos wrote:
CD Boards include a few outside things. Clearly cd, dvd, bluray.
Also most tape drive boards. Super floppy type (dozens or hundreds of megs).
Every post I've gone back through says those 3.5" floppy boards go (high) peripheral, almost entirely due to the pins being on them.
So maybe you're referring to super floppy? In which case I would love pictures so I can learn.
On the board here though you said it's 5.25" and based on what I found searching, CD/DVD is grading that too low.
