It is currently Sat Nov 07, 2026 7:26 pm
PostPosted: Sat Feb 25, 2023 7:23 pm
PostPosted: Tue Feb 28, 2023 9:13 am
Just as a forewarning, my grades may not always be correct but are correct most of the time, just on here helping and even learning myself.
1. I would remove the SLA4030 Transistor Arrays and probably the Cosel Power supply in the center so it for sure fits into low Telecom. Those other components hold a decent chunk of weight
2-5 - Low Telecom
6 - High Peripheral
7 - Low Telecom
8 & 9 - Peripheral High
10 - I think this would be embedded Motherboard grade BUT it has the gold tab on the corner of the processors so I actually don't know what grade that bumps it up to. This is one you may need to Email Chris about as I haven't had one of these yet.
11 - High Peripheral
12 - This should be two separate boards putting the left side as high Peripheral and the right as low peripheral
13 - High peripheral but the gold flashing may put this up to low telecom
14 - Same situation as 10
15 & 16 - High Peripheral
Hopefully that helps narrow it down for you. These may not be official grades but that's where I personally would put them in my piles. Definitely ask about the two embedded motherboards.
PostPosted: Tue Feb 28, 2023 1:59 pm
Reminder: too many boards in one post. Makes it difficult for those who would help grade to chase two pages of pictures and correlate them. Usually 5 or 6 photos is the suggested maximum
