It is currently Wed Sep 30, 2026 3:21 am
PostPosted: Fri Oct 13, 2023 9:54 pm
Could someone help me identify
PostPosted: Sun Oct 22, 2023 9:43 pm
The larger board may be a gold edge board (still not sure on this category) but I'm thinking low telco at least.
The smaller board; not sure what I'm looking at. Is the board adhered to a piece of metal?
PostPosted: Tue Oct 31, 2023 10:37 pm
The smaller ones that are silver on one side and gold on the other are made of solid aluminum. On the back of the silver side there is a small strip of green fiber board running across in a tooled out slot. Thanks for your time.
PostPosted: Tue Oct 31, 2023 11:04 pm
The smaller boards whole might be able to go midgrade as is. I'm not sure. If the boards can be separated from the aluminum easily the gold facing side boards may hit that gold edge category, again I'm not certain of that, and the green boards are probably midgrade.
PostPosted: Mon Nov 06, 2023 3:28 pm
Ok thanks
PostPosted: Sat Nov 18, 2023 2:40 pm
If you haven’t sent them email Chris on these. They’re a special quote type. They are outside of the base classes.
