It is currently Sat Nov 07, 2026 5:37 pm
 Post subject: Board Ident help...
PostPosted: Fri May 17, 2024 2:22 pm
Any help you can give! Thanks!
 Post subject: Re: Board Ident help...
PostPosted: Fri May 24, 2024 6:29 pm
Top board I would consider High Grade Telco. The second board will probably go as clean gold finger board. the 3rd board I would email Chris directly and ask him (unless lost or another admin wants to jump in here). This 4th board, if I were you I would trim the fingers off, definitely pull off that beautiful CPU as it's worth much more by itself than on the board, and then the board would be a high grade telco.
PostPosted: Thu Jun 13, 2024 5:10 pm
Well, thanks for your recommendations... I sent 17 pounds of that top board in and they down graded it to perph high grade.... I had emailed Chris prior to even posting here and hadn't heard from him... Guess they get pretty busy.
Although I think my scale must have been messed up that day cause they made a lot of adjustments to that invoice.
