It is currently Sat Nov 07, 2026 5:37 pm
PostPosted: Fri Jul 12, 2024 1:59 pm
These are actually all the same other than what I have removed from them. The backs are all the same. I am asking:
1. As there are phone jacks, does that make these telecom boards?
B. Given the various states of depopulation, how would each one grade?
Thanks for the information!
PostPosted: Thu Jul 18, 2024 7:28 pm
Depopulation down grades the board always. It was something easy to classify and after depopulation it becomes a mystery so it falls into low grade. Phone jacks do not make a board telecom.
Best advise is to send an email to chris@boardsort.com and pray to your gods for mercy.
PostPosted: Sun Jul 28, 2024 10:32 pm
Thanks Ropeman,
Your message about depopulation is heard loud and clear. I have to ask though are there some things that if taken off a board would actually raise its value. My overall sense of the board grading is it comes down to weight of valuable metal - I suppose gold primarily - as a percentage of total weight. Some boards must have +/- known quantities and so they are graded as such. Am I on target?
If so, I don't understand your position on these boards. Yes, I killed one of them but the rest I have essentially only removed the copper with the yellow tape and the jacks - essentially lowering the dead weight. What is left is about a dozen ICs, one flat pack which has gold markings. The boards are thin hard plastic; the gold is thick enough that it can be felt, and it lines little holes through the board. If my premise is right, would that still be considered low grade?
PostPosted: Thu Aug 01, 2024 8:32 pm
You are correct, removing ICs it totally different than removing plastic jacks and copper/steel transformers. The odd part is it's not very often that you can change the grade of a board by taking off smaller parts like that. I had some telecom boards that did get upgraded by taking off large transformers, but that's rare. I guess the weight of smaller parts, excluding heat sinks, is already factored into the class of the board.
