It is currently Fri Jun 19, 2026 6:55 am
 Post subject: What type
PostPosted: Tue Oct 08, 2024 4:30 pm
Type
 Post subject: Re: What type
PostPosted: Sun May 24, 2026 7:35 pm
Low Peripheral. Even if you remove the metal bracket.
PostPosted: Sun May 24, 2026 9:42 pm
Nothing on the back? Seems like there's something there with the wire and metal tabs coming through the board.
Do remove the battery! And if you pull the brown tabs out on the wire connectors the wire will slip right out.
PostPosted: Sun May 24, 2026 9:50 pm
Wow. I missed the battery. And removing the flex circuit.
So what is your evaluation? Marked141!!!
PostPosted: Sun May 24, 2026 9:57 pm
No evaluation due to the appearance of stuff on the back that can't be seen
PostPosted: Sun May 24, 2026 10:12 pm
The usual problem with posted photos. Front view only. No back side photo. I think some forum members sincerely assume a board will be recognised for value with only a front view. That is not the case. Millions upon millions of circuit boards are manufactured. The same board in various configurations and revisions.
Absolutely a good comment Marked141. Hope it sounds out through all forum members.
