It is currently Sat Nov 07, 2026 6:43 am
PostPosted: Wed Jan 01, 2025 1:18 pm
[url][/url]I have over 4000 of these boards. they came out of towers with a ton of wire wrapped pin boards . I'm assuming it's telecom.... high? I'm taking the black plastic bracket off. do I leave the connector ends on? thanks
PostPosted: Wed Jan 01, 2025 3:15 pm
turns out I have a ton of questions about these boards . should I email Mr. Chris directly, or is there someone else I can contact with pics and questions??
PostPosted: Mon Jan 06, 2025 12:52 pm
First question, you say you have over 4000 of these boards and then show two different boards. Are all the boards the same or do you have over 4000 boards that are similar but not exactly the same? The reason I ask is that I think the first board is low telcom and the second is high telcom. Do take the bracket off, but don't remove the connector.
