It is currently Wed Sep 30, 2026 9:15 am
 Post subject: Please grade
PostPosted: Sun Feb 16, 2025 8:14 am
trying to get a shipment of boards together to ship to you.
Thank you.
 Post subject: Re: Please grade
PostPosted: Sat May 16, 2026 3:46 am
You should lay out your boards in a more orderly fashion. Also. One board per frame. Show front and back of any particular board in question is ideal to get responses. Using labels is great also. I can say this much concerning the two boards labeled #2. Cut the connector with wire from the board. Also. I see glass fuses on the one board. You must remove glass fuses before sending in.
