It is currently Tue Sep 29, 2026 9:23 pm
PostPosted: Wed Feb 26, 2025 11:44 am
I have a bunch of these and don't know whether to throw them in high peripheral or if they may make something better. Any help would be appreciated. Thanks
PostPosted: Fri May 08, 2026 5:09 pm
You should remove the shielding. That can help getting a better grade.
PostPosted: Fri May 08, 2026 6:51 pm
I'm not sure that's shielding my whiskered friend.
High telco seems like a possibility but not 100% on that
PostPosted: Fri May 08, 2026 7:06 pm
Its a module. That metal on it should be able to be removed easily. Its a high frequency module probably a ceramic substrate with components on it. The gold underneath it. On the PCBs opposite side is a give away. It's high frequency circuitry underneath. And. A shield on top. That type of shielding is necessary for circuit stability.
So as is. Not removing the metal. I would evaluate at High Peripheral. I am curious to see what is under the shielding.
PostPosted: Fri May 08, 2026 7:13 pm
¯\_(ツ)_/¯
It's a tough angle.
More pics please?
PostPosted: Sat May 09, 2026 12:07 pm
It is capped but it does look like its solder to the chip. The cap will be removeable if you see a slight edge above the chip. Take a small flathead or something small enough to fit that hole and pull up. You will know if it can be removed or not.
Low tel at the least most likely High tel.
Side note: make sure to remove most, if not entirely, thermal pastes and sticky tacks/adhesives on top of those chips.
