It is currently Sat Nov 07, 2026 5:06 pm
PostPosted: Thu Mar 03, 2016 12:08 am
First post, been browsing here for a while! Sort of new to ewaste, but not new to regular metal (copper, iron, aluminum stuff like that) I've been saving up this stuff for a long time, and need to clear space for more, so starting with some small stuff. The small boards I have here came from laptop CD-ROM drives, do they still count as a CD-ROM board or no?
The connector pins were not attached to the last hard drive board I have here, is it worth less or the same without it? I will have more to post tomorrow.
PostPosted: Thu Mar 03, 2016 11:07 am
The top picture will all be cell phone boards. You'll need to clear off some of those heat spreaders though. The quote rate is for clean boards with little to no metal.
PostPosted: Thu Mar 03, 2016 11:15 am
Hdd boards.
1)hdd board
2)hdd board
3)hdd board
4)hdd board
5)telco
6)peripheral
7)hdd board
8)hdd board
9)peripheral
Explanation;
Any full or half size board (top 3 and bottom 3) i class as hdd board if it has the pins or port/jack
Telco or peripheral if it does not depending on ic population
For laptop/2.5 inch or smaller boards.
I go hdd board if it has the pins (ata/scsi) or complete port for sata/sas/fib.
If it has a flat wire connector it goes telco or peripheral depending on ic population
