It is currently Sat Nov 07, 2026 1:27 pm
 Post subject: remove switches?
PostPosted: Thu Jul 24, 2025 4:41 pm
remove switches?? just pull switch caps off?
Thanks
 Post subject: Re: remove switches?
PostPosted: Fri Jul 25, 2025 2:46 pm
Switches can add value to a board. Not sure if these will or not, depends on what's in them and what the weight is like.
I would guess at least low peripheral but lean towards high peripheral on the green since there's other stuff on the board. Not sure on the black board, there are some gold pins but most of the weight is in the switches I'd guess, so leaning low peripheral.
