It is currently Sat Nov 07, 2026 2:46 am
 Post subject: Few more ID needed
PostPosted: Mon Oct 20, 2025 4:12 pm
Can I remove the gold fingers of bottom board without degrading the board ?
Thanks
 Post subject: Re: Few more ID needed
PostPosted: Tue Oct 21, 2025 1:49 pm
The board with the fingers should go at least low if not high telecom as is after the battery is removed. Don’t trim. High peripheral if trimmed.
The board to the left of the one with fingers and the board in the middle of the top row should also be able to go in low telecom.
Rest high peripheral.
Remove steel from the back of the second board from the right, it is under the long yellow barcode sticker.
PostPosted: Thu Oct 23, 2025 12:21 pm
Bottom row second from left is an apple cpu
PostPosted: Mon Oct 27, 2025 4:49 pm
Thanks and here is the board with out shields
PostPosted: Tue Oct 28, 2025 7:19 pm
From left to right in the photo
top row:
low peripheral (junk on the back pulls it down for me)
low peripheral unless there is something good under that blocky thing on the back
High peripheral
motherboard from an ASUS netbook, I think can go as laptop MOBO
High peripheral
bottom row:
Low peripheral (not many true chips, but may squeak through as high peripheral.)
apple CPU
High telco (remove the battery). (I would keep the gold fingers intact, though you can sometimes trim on high telco)
high peripheral
other photo without heat shields is gold finger card
