Post new topic Reply to topic  [ 16 posts ]  Go to page 1, 2  Next
PostPosted: Sat Mar 12, 2016 12:38 pm
i recently scrapped out around 40 lcd monitors and was wondering what to grade certain boards at and what i could pull to increase the grades on these boards. i sorted out all of the obvious brown boards, but i some that are either mid grade or peripheral(no clue how to distinguish), and some thin boards with lots of gold plating but only a few ic type chips, lots of mlccs though. I also have a bunch of the cables that are attached to the actual lcd screens. not sure if theres any value to them or not but i have a few that are gold plated and the rest have some sort of chip on them. working on sorting out my first shipment and i want to know whats going to be worth sending in and what i should sell to my local yard( they only pay 10 cents a pound regardless of grade. ill do a little math on some of these but the low grades will not be shipped for sure. ill try take some pics in a little bit here.
PostPosted: Sat Mar 12, 2016 12:48 pm
These are the cables from the lcd screens. 1.4 oz
PostPosted: Sat Mar 12, 2016 12:51 pm
These are the lcd cables with gold plating. .2 oz
PostPosted: Sat Mar 12, 2016 1:23 pm
Most boards in lcd screens run from mid grade (the power board) or peripheral for almost everything else. Smart TVs often have a SOC board that will go green fibre with metal or telco.
And finally very high end ones with total gold plated external connectors and a crap load of ICs on the connector boards will also usually get telco.
Those flat wire ribbons you posted.
I cut the contacts off. Gold contacts go with gold fingers
Silver contacts go with silver/tin ram and the wires go as mixed wire (for boardsort) or silver/nickel and/or flat wire for large local yards. I have never had one of those little black rectangles scanned so I'm not sure what the material is but i leave it on the wires.
PostPosted: Sun Mar 13, 2016 1:59 am
Thanks for the reply. My internet was acting up so I couldn't finish posting pics. Here's the ones I was thinking might be peripheral?
PostPosted: Sun Mar 13, 2016 2:00 am
These are the thin ones with lots of gold plate
PostPosted: Sun Mar 13, 2016 2:01 am
These don't have much on them so I'm guessing they're low grade?
PostPosted: Sun Mar 13, 2016 2:02 am
And here's the bulk of the haul sadly. Lots of brown boards. I'm assuming if it's a brown board it's basically automatically low grade?
PostPosted: Sun Mar 13, 2016 2:13 am
Everything you posted looks peripheral except the last bottom picture of power boards (low grade)
PostPosted: Sun Mar 13, 2016 2:16 am
[edit] we posted at the same time! I pull the IC chips and transformers off the brown boards
