It is currently Sat Nov 07, 2026 2:55 pm
 Post subject: Industrial charger
PostPosted: Sat Nov 15, 2025 10:28 am
I have 30 to 40 industrial chargers I'm scrapping. Trying to see if the primary boards are worth anything. Thank you for the help.
 Post subject: Re: Industrial charger
PostPosted: Sat Nov 15, 2025 10:39 am
Front of circuit board
PostPosted: Sat Nov 15, 2025 10:41 am
Back of circuit board
PostPosted: Sat Nov 15, 2025 2:26 pm
Mid grade. I don't see much on the board that could take it to Low Per.
Make sure to take all ferrous metals and connector ends off the boards. Remove excess wires too. The screws, wire eyes, the clipped connectors, and data cord(ATA).
PostPosted: Sat Nov 15, 2025 4:41 pm
Thank you. At 50 cents a lb. It's probably not worth sending in. Thank you.
PostPosted: Sat Nov 15, 2025 4:45 pm
For this board to make sense in my book:
Take a jigsaw and cut the board in half. Use the white line as a divider. The top of the board moves on. The bottom board has no future here.
Next remove the remaining junk (Cut wire harnesses, large capacitors etc.)
You have what looks like 13 or 14 IC's and gold pins. I would classify what remains as HGP all day.
Abbreviations
HGT - High Grade Telecom
LGT - Low Grade Telecom
HGP - High Grade Peripherial
LGP - Low Grade Peripherial
MGB - Mid-Grade Board
LGB - Low-Grade Board
PostPosted: Sat Nov 15, 2025 6:11 pm
Fairly easy to split it. Does this look a little more valuable?
PostPosted: Tue Nov 18, 2025 12:57 am
Looks good, see if you can carefully cut between this line here. It would look better and keep more components from falling off.
PostPosted: Tue Nov 18, 2025 12:58 am
Upgrade to Low Per
PostPosted: Tue Nov 18, 2025 1:09 am
The circled areas are points you do not want to disturb. Keep them on. Try to carefully run that pink line I drew up.
