It is currently Fri Sep 25, 2026 8:00 pm
 Post subject: LED Panel boards
PostPosted: Tue Dec 09, 2025 3:30 pm
Gonna be scrapping out a whole pile of led panels later this month, gonna end up with over a hundred of these boards. Would the fact that one entire side of the board is carpeted edge to edge with little LEDs add or detract from the grade/price?
 Post subject: Re: LED Panel boards
PostPosted: Wed Dec 10, 2025 1:35 am
To the degree of what it's attached to, and how good or populated.
We had a discussion on these recently, and those things are cool as hell.
E-mail Chris at BS for a quote. These look familiar to the ones that were in question last time but I don't remember what was determined of grade/class
PostPosted: Wed Dec 10, 2025 1:36 am
It's highly populated. I can see High Per to Low Tel. I'm unsure if it makes High Tel, but like I said I can't recall what was determined.
PostPosted: Wed Dec 10, 2025 11:12 am
I can't imagine the leds add or detract much.
The attachment points would probably be more likely to lower the value but should be negligible.
The other board Spence is referencing never did get an exact grade posted and was slightly different. So, unless there's something I'm missing, I would guess low or high Telco on this one, leaning towards high.
PostPosted: Mon Dec 15, 2025 10:04 pm
Finally got the chance to start breaking these led tiles apart tonight, these two boards were inside. The green board is the receive card, basically the brain and network interface of the tile, while the black board functions as the hub board that basically functions as a backplane board between the module boards I originally posted and the receive card.
I assume high periferal for the green board, but would the black one have enough gold pinned connectors and small components to make low periferal grade?
